Ron
08-13-2003 09:16:30
Re: Re: Re: fluid in rear tires!!! in reply to Trevor, 08-12-2003 11:57:39
It depends a lot on if the plow is properly "scoured".....We have all kinds of soil here...Clay, Yellow Wax, Black Wax....the usual... Only time I stay out of the field is when the Black Wax is hard as concrete.....!! That is when I start to break coverboards, and hardly can get any traction from the hard ground....!! Dad's '57 WD-45 came with a semi-mounted 4x14" plow, and I put one on mine, also... We can get a lot done, with 8 furrows turning at the same time..!! We use less gas with 4 bottoms..always in 2nd gear...works a lot better than 3 bottoms in 3rd gear....!! Tires need to be at least 50%, and all wheels loaded--weight on the front is good, too... Perfect balance of power to load...!! Don't under-estimate the power of a WD-45..it has Great Torque....!!! You won't see many 100 horse tractors pulling an 8 bottom plow....!!!! We can turn 50 acres in a good day...on 3 tanks of gas a piece. You just have to set the power screw about 1/4 turn richer, to get a BIG boost in power...!! I run it leaner when mowing, baleing, etc.. Stands a flame about 12" above the muffler, when plowing...top half of muffler red, and the front end riding "light"...!! Often plow at nite without the lights, if there is a little moonlight...!! Can see better than with the lights on...!! I use a #37 International disc and harrow..use duals with that...Tractor looks wider than it is long, but will almost Float.....!! Lots less slippage..always in 3rd gear... Use the JD"B" with a "Soil Surgeon" over plowed ground to level it...Great Tool.....!! Just add weight as needed, and handy to put rocks on, too...!!
