traction booster
Joe
08-09-2003 18:43:46
does a wd have traction booster?
Fred
08-12-2003 19:09:14
 Re: traction booster in reply to Joe, 08-09-2003 18:43:46
Ron has the right idea. listen to him.
Dave K
08-10-2003 20:26:23
All WD's have traction boost.
Ron
08-10-2003 11:29:16
Yes, the WD has the same traction Boosting set-up as the WD-45....only there is no gauge.... You just drop the plow, and when it is in the ground, raise the hydrolic lift lever a little.. The amount will vary on wheather the shears are new ( raise the lever a little) or worn( raise the lever a little more).. In VERY hard pulling, you will know when you have too much "Boost"..the front wheels will start to come off the ground..!! In Very hard plowing, you will maybe have the Hydrolic lever all the way down, and still have to hold the hand clutch in, to keep the front wheel close to the ground...!! Great FUN.....!!! Ron.
Nebraska cowman
08-10-2003 06:04:00
joe, on the WD you have to change the linkage for draft control. (should be a decal on the side of battery box)
Sid
08-09-2003 20:01:58
Yes As near as I can tell mine is a 1951 and it has traction booster.
