CA: rotary tiller
Carman
08-09-2003 11:10:07
I am thinking about acquiring a rotary tiller for my CA and the hp rating for the tiller is 15-18 hp. Has anyone have any experience using a old 1953 CA with a rotary tiller?
Thanks
Eldon
08-09-2003 15:23:35
 Re: CA: rotary tiller in reply to Carman, 08-09-2003 11:10:07
Low gear on the CA (2.0 mph) is a little on the fast side for tilling. I run a 5' Howard behind my D17 and low gear (1.8 MPH) is still a little fast and sometimes takes all the power the 17 has to pull it. It is a challenge to operate the hand clutch and hydraulic lift at the same time. and if you get hooked on a root how would you turn off the pto to raise the tiller? On a CA you almost have to take the pto shaft off when that happens.
