power steering
jack iwakiri
08-08-2003 10:22:23
Can power steering be added to a wd45? If so where can I find the parts?
Dennis
08-11-2003 20:29:49
 Re: power steering in reply to jack iwakiri, 08-08-2003 10:22:23
Jack,
I added PS to my WD 45. I found a guy that sold me a charlynn unit from an International 340. All I had to do was cut a piece out of the upper steering rod and put this unit in place. I had to make an offset for the throttle rod to get around the charlynn unit. You need a hydraulic pump to power the PS. I mounted another hydraulic pump ahead of the crankshaft by removing the crank unit but I am also using this new pump to operate a loader etc. If all you need is to power the PS, a small PS pump from a car would do but you have to find a way to mount it. One guy told me he moved the generator to the upper right of the engine and then a PS pump could go where the generator was located.
Since I installed my PS, I ran across an identical unit at an auction which I bought to have around for future use whereever. It has the charlynn unit and a pump and the connecting hoses all intact. I now am of the frame of mind to sell the unit instead. If you are still looking, send me an email and we can work something out!
Dennis
Shakey
03-18-2006 21:42:44
 Re: Re: power steering in reply to Dennis, 08-11-2003 20:29:49
Dennis...If u still have that Charlynn yet...how much u want for it? thanks..Scott
Jim (Mi)
08-08-2003 10:58:06
Jack, look thru the for sale adds I think someone might have some. I have a Char-Lynn on for my WD, I am going to be getting rid of soon. You could get one off a D series tractor, or the later WD-45's had them. I have some pictures of some 45's with them installed. If you do not get any additional help, e-mail me, and I should be able to scan them, and e-mail to ya.
JMS/MN
08-09-2003 15:55:51
 Re: Re: power steering in reply to Jim (Mi), 08-08-2003 10:58:06
D series power steering is not the same as the WD45. Entire system is different. There are aftermarket units available, or you may find one from a parted out tractor. I think factory power steering was available about 1956.
Jim (Mi)
08-11-2003 07:46:43
 Re: Re: Re: power steering in reply to JMS/MN, 08-09-2003 15:55:51
Humm, now that is interesting, since it is a contained system, all you have to do is get a bracket holding the pump to the body, and a mounting location for the pulley. I thought aftermarket char-lynn's were set-up for both. Learn something new every day. :>)
jack in ca.
08-10-2003 10:04:22
What are the names of the after market power steering units? Is the installation difficult?
jack in ca.
08-10-2003 10:15:41
 Re: Re: Re: Re: power steering in reply to jack in ca., 08-10-2003 10:04:22
I'm confused,are the power steering units activated by a seperate hydralic pump unit?
