Steering Wheel Repair/Recover?
Matt (Ohio)
08-07-2003 09:17:22
Does any one know of a good way to recover or repair a cracked steering wheel cover?
Joe(tx)
08-08-2003 05:04:55
 Re: Steering Wheel Repair/Recover? in reply to Matt (Ohio), 08-07-2003 09:17:22
The Eastwood co. has a steering wheel restoration it. Go to http://www.eastwoodco.com/. Select "Interior & Exterior" from the menu on the left. Look for "Complete Steering Wheel Restoration Kit item no: 52194 Z". Any good epoxy filler will work also.
Tom Westerfield(W. Ky.)
08-07-2003 16:16:03
Bondo has worked well for me. After filling cracks and broken out chunks, wrap with Saran wrap to make it smoother. The latter will cut down on the sanding.
Dave K
08-07-2003 12:30:35
I repaired mine with JB Weld. Just fill in all the cracks, let cure, then sand it and paint it if you wish.
Dave
Kim
08-07-2003 10:15:26
Matt, I've never fixed a steering wheel myself ;)
I wanted to tell you though that there was discussion recently on another forum on this subject. One gentleman posted a detailed description of how he repaired a steering wheel, it may be of interest.
Just click on the link here to read his info.
Best of luck with your repairs,
Kim
AZ Jack
08-07-2003 22:04:45
 Re: Re: Steering Wheel Repair/Recover? in reply to Kim, 08-07-2003 10:15:26
Very good article Kim-I have repaired several steering wheels using different methods. Bondo will show hairline cracks in the hot sun after a period of time. Resin seems to work far better, JB the next best. Hi temp black paint will hold up well in even Arizona sun. I get mine at good old Wally world. Jack
