belt pulley oil seal
randall
08-06-2003 18:15:52
I have a 39 B I need to replace the belt pulley oil seal on and cant find a source for it. It has the oil return grooves on the shaft. Any ideas on a place that sells the leather type seal? Any help will be appreciated. Thanks
Steve in N.J.
08-07-2003 16:06:11
 Re: belt pulley oil seal in reply to randall, 08-06-2003 18:15:52
Randall, If you have trouble finding the speedi-sleeve and seal locally, we keep them in stock. Drop us a line if ya need the set. Rod- Great pix and explanation!
Steve/B&B Custom Circuits
Rod (NH)
08-06-2003 19:29:23
Hi Randall,
I can't help you locate a leather seal since I couldn't find one either. Here's how I handled the same problem with my '42 B. It worked great!
third party image Rod
randall
08-07-2003 05:59:02
 Re: Re: belt pulley oil seal in reply to Rod (NH), 08-06-2003 19:29:23
Hey Rod, good idea. I wonder if J B weld would work by filling in the grooves? Thanks
Rod (NH)
08-07-2003 09:35:33
 Re: Re: Re: belt pulley oil seal in reply to randall, 08-07-2003 05:59:02
I understand that some have filled in the groove with an epoxy. I assume JB Weld would work also. The problem I see with that is the very limited access to be able to prior clean and post-sand/polish for a good smooth finish with the shaft in place. That's why I went the way I did...I did not want to remove the shaft. Plus, mine is a working B and I use that pulley extensively to drive a cordwood saw. I wanted a good permanent fix that I wouldn't have to mess with at a later time.
