elecrical
greg
08-06-2003 03:14:33
ac,51,wc I WOULD LIKE TO REWIRE THE WHOLE TRACTOR.THERE IS A 12 VOLT SYSTEM AND I JUST PURCHASED A DELCO 10 SI ALT. MADE THE MODIFICATIONS TO MOUNT ALT. WHERE DO I GO FROM HERE? WOULD LIE TO PUT ON NEW GAUGES,(VOLT,AMP)STARTER SWITCH ETC. UNABLE TO FIND A WIRING DIAGRAM.
Steve in N.J.
08-07-2003 10:16:42
 Re: elecrical in reply to greg, 08-06-2003 03:14:33
Greg, We offer a 12V conversion wiring system. We offer it with or without alternator. Comes with voltmeter, key switch, alternator brackets, etc. All the stuff to make it happen. Drop us a line if interested...
Steve/B&B Custom Circuits
steve
08-06-2003 19:49:32
send me an e-mail and i can send you a diagram. Basically the 2 or "F" terminal on the side is connected to the big 1/4 inch lug on the back and is always HOT- connected to the + terminal of the battery thru the amp meter. THe other spade terminal 1 or "R" is the signal terminal and has a signal voltage applied when running. You must run it thru a toggle switch or key to disconnect when off. Also the 1 line needs an inline reisitor 10 ohm, 10 watt to drop voltage to make it charge "good" at a lower rpm. You can get it at radio shack for $1. Starter is o.k. on 12 volts. Must be negative ground for the alternator. Need 12 volt coil or resistor added to the old 6 volt coil.
