Head stuck?!!?
Frank
08-04-2003 18:12:56
I am replacing the head gasket on my wd and I can't get the head lose to get it off. I got all the bolts out and tried prying and wiggling it off to no avail. Any suggestions.
thanks in advance
George G
08-06-2003 05:24:55
 Re: Head stuck?!!? in reply to Frank, 08-04-2003 18:12:56
Count your head bolts. Should be 15 bolts. Twelve 1/2" bolts and three 3/8" bolts
boog
08-05-2003 12:54:54
If this is a running tractor, just loosen all of the headbolts and start it up. It'll pop loose after a couple of quick throttle blips.
Bob D. )La)
08-04-2003 18:28:33
Frank, I just had a similiar problem on a CA. After making sure I hadn't missed a bolt somewhere, I used a short piece of 4X4 and a heavy hammer to break it loose. Just don't hit the manifold. Worked about the 3'rd or 4th lick.
cooper
08-05-2003 05:10:43
 Re: Re: Head stuck?!!? in reply to Bob D. )La), 08-04-2003 18:28:33
Put the plugs in and rock it gently. If all the bolts are out, it will give.
sparkplug
08-05-2003 12:17:38
 Re: Re: Re: Head stuck?!!? in reply to cooper, 08-05-2003 05:10:43
get a green tractor and u wont have a problem
Frank
08-05-2003 18:25:12
 Re: Re: Re: Re: Head stuck?!!? in reply to sparkplug, 08-05-2003 12:17:38
Your right if I had a green one, I wouldn't have a problem with it. It would be sitting in the front yard as a yard ornament.
Brad Gyde
08-17-2003 19:51:50
 Re: Re: Re: Re: Re: Head stuck?!!? in reply to Frank, 08-05-2003 18:25:12
I dunno, a neighbor has a JD "A" that he uses to rake hay and a few other light chores, and I'll be darned if he don't put a head gasket on it every 2 years or so...
as for your stuck head, I had one similar on a "WC" I was parting for the block, I had the whole front end of it hanging off the ground by the chainfalll, jumping on frame rails until it came off... took a bit too (And I'm not a lightweight either) Found out in the end that the stuck bolt hole had a crack and the water got in there and rusted it pretty good.
Good Luck,
Brad Gyde
