WD45 Diesel Piston and Sleeve Kit
Chuck Luedtke
08-04-2003 16:17:01
Where is the best place to call for a piston and sleeve kit for A wd45 diesel. The couple of places that I have tried so far no longer carry them or say that they are discontinued. Wasn't the D17 Diesel the same block and bore with only a longer stroke crank. Would that kit work or is there something else I can try? The motor I have is tight and the one sleeve after cleaning it up has a pit from rust about an eraser head in diameter and probably 3/32 inch deep. Another piston has a similar pit. Or is there a way that I can fix what I have to save some money. All the other pistons-sleeve look good. Thanks in advance.
W.W.
08-10-2003 18:44:49
 Re: WD45 Diesel Piston and Sleeve Kit in reply to Chuck Luedtke, 08-04-2003 16:17:01
No the WD45D had a 230 engine but the bore was like 3 3/8 or 3 7/16 where the D17 and D19 were the 262 with a 3 9/16 bore. The stroke should be the same. We just checked a gas 230 block to see if it could be used to replace the 262 diesel block and we are sure it's the same block. I would see if the 262 sleeves and pistons will fit right in your 230 block.
