AC G Carburetor Repair
Dennis of KC
08-04-2003 10:47:39
The carburetor of my AC G runs over even with a new float. How can I remove the main jet and float valve seat from an AC G carburetor? I can�t break them loose using a large screwdriver. Can I use an impact driver to remove them or will it break the heads off? Will an extractor work? In addition, the manual is vague about how to set the carburetor float. Please explain how to set the float �� from the body of the carburetor. As an alternative, please give me a name of a reputable carburetor rebuilder. Thank you for your help.
Dick L
08-04-2003 11:23:46
 Re: AC G Carburetor Repair in reply to Dennis of KC, 08-04-2003 10:47:39
I had to use heat to get the seat for the float valve out of mine. I regrind a large screwdriver to fit the slot in the seats of float valves before I start to keep from rounding out the slot. I put vice grips on the screwdriver shaft, put the carb in a vice, and push down real hard on the handle as I turn the screwdriver with the vice grips. If it does not break lose the first try I go to the tourch for heat.
