WD45 Starter Removal
tushuz414
08-04-2003 08:18:43
Someone please explain the starter removal on my WD45. I do not see the expected bolts to remove. Thanks for your time.
JMS/MN
08-04-2003 09:22:51
 Re: WD45 Starter Removal in reply to tushuz414, 08-04-2003 08:18:43
The starter is held in place with only one bolt; it is on the side of the casting that the starter fits in to, and has a locknut on it as well. Loosen the locknut, remove the bolt- the end of it is tapered- that's what centers the starter in the housing.
tushuz414
08-04-2003 11:29:01
 Re: Re: WD45 Starter Removal in reply to JMS/MN, 08-04-2003 09:22:51
Thanks, I went out and checked it out. I'll disassemble it shortly.
Carroll
08-06-2003 19:11:56
 Re: Re: Re: WD45 Starter Removal in reply to tushuz414, 08-04-2003 11:29:01
Bet you'll find the bendix spring broken. cp
tushuz414
08-07-2003 21:42:36
 Re: Re: Re: Re: WD45 Starter Removal in reply to Carroll, 08-06-2003 19:11:56
I will check that out. Thanks for the point.
