WD45 Strater Problem?
tushuz414
08-04-2003 08:15:58
Last night I was trying to put every thing up, changing and moving implements. I shut the WD45 off and when I went to restart it all I got was and electrical softer buzz/hum noise from the starter area. I charged the battery up and checked its voltage--all ok. But the starter still makes the same buz/hum and will not turn over engine. Ideas? Tests?
calh
08-08-2003 22:05:19
 Re: WD45 Strater Problem? in reply to tushuz414, 08-04-2003 08:15:58
Check the starter button for a bad contacts. If thats the problem you may be able to turn the post where the battery cable connects around and save the cost of a new switch.
acd17toy
08-04-2003 20:37:10
one of two things could have happened. the starter is locked to the fly wheel, or the nose cone could have broken off. pull the starter out and check the nose cone. re install starter and see if it will work.
