D15 II Engine kit
Lee Hartsell
08-02-2003 13:14:33
I have been searching for a total rebuild kit for my tractor.. Seems that i can get one for the 138 and 149 engine.. Just need one for the 160 inch engine and no where that i have looked has that listed.. Any ideas? Any help appreciated.. Thanks LEE
Larry806
08-03-2003 20:04:37
 Re: D15 II Engine kit in reply to Lee Hartsell, 08-02-2003 13:14:33
I need a crankshaft & bearings for a 160 I haven't been able to find them reasonable anywhere
norm
08-03-2003 19:22:17
we can furnish your 160 motor kit approx $800.00--includes bearings,gaskets and all
sleeves rings liners etc.--call1-574-342-4545-days--8-5
Charley
08-03-2003 16:11:26
I too searched for the Series 2 engine kit in the aftermarket with no luck. At the time Central Tractor did have a rebuilt short block for big money. They wanted to check the casting number from my block to be sure all was right and they discovered that it was not the 160 but the smaller bore. The tractor bears a D15 Series 2 serial number so somewhere along the line someone replaced the block! This was good for me cause I was able to purchase a complete Sealed Power rebuild kit for about $325 if I remember correctly. So check your casting number and be sure it really is the larger bore. You might get lucky! Or not, depending on your point of view??
Lee in MI
08-02-2003 15:28:44
Send www.internalengineparts.com an email and tell them what you have and they will get back with you. I got Perkins head gasket set from them, sent right to my door.
DanD.
08-02-2003 13:25:09
Not available from any aftermarket place I know of. Only source is AGCO. Go to their website and use their find dealer function if you don't know who your nearest dealer is. AGCO's engine kits are very reasonably priced anyway, although the 160 cid engine is expensive for its size. Also, check out the allischalmers website.
Lee Hartsell
08-09-2003 15:46:16
 Re: Re: D15 II Engine kit in reply to DanD., 08-02-2003 13:25:09
thanks fellows for all your help. I have been out of town. It is getting hard to find some of these tractor parts these days. The area i live in has long seen farming go away and the tractor dealers around here keep there business up with small stuff and lawn mowers so when you go in the store lookin for bigger older part they scatch there heads a little..
