Surging
Mike
08-01-2003 17:32:03
I hear more and more people talk about surging and anti-surging springs for the governor. This sounds like maybe the problem with my Ca but i would like to know what surging is. Our Ca has problems under load, the throttle wont catch up with itself. So this leads me to believe there is a problem with a) the fuel,carb, etc b)not enough spark c)ignition timing. Also can the ignition timing be adjusted via the distrubuter like on Farmall. By the way this tractor uses a mag. Any help is appreciated because we use this tractor for mowing and the grass keeps growing. Thanks in advance. Mike
Tyler(WA)
08-01-2003 22:57:17
 Re: Surging in reply to Mike, 08-01-2003 17:32:03
Mike,
I think what you are asking about is why the governor dampening spring is necessary.
Governors are pretty powerful at what they do while carberators and their linkages offer little resistance. If there is no resistance, the governors control is too much and the engine oscilates or "hunts" for the correct RPM.
The dampening spring puts a little resistance in the linkage and stops the governor from over-reacting.
Dave K
08-01-2003 18:00:01
Timing with the mag can be adjusted for advance or retard by loosening the screws on the base and turning the mag slightly in whichever direction you need to. You could have any or all of the problems you mention. I do not clearly understand what you mean by the throttle not catching up with itself? Does the governer move the throttle plate when at full throttle and you load the engine? When you drive, if you apply a load (the brakes) the throttle should open even though the throttle is already set in the full open position, remove the load and the governer will return the engine to full throttle, no load condition. If you mean the governer opens the throttle but the engine is slow to respond then you may be talking timing or fuel. I would suspect a fuel problem. Open the drain on the carb for a full min and check for a good strong flow of fuel. (engine off) If it peters out or flows slowly then you probably have trash in the outlet from the tank. Remove filter bowl and check for good flow, still bad you will need to screw the fittings out of the tank outlet and clean everything. It is also possible that the fuel cap is not venting, so not allowing air to enter the tank as fuel flows out. If this checks out you may need a carb cleaning, a carb rebuild kit, or intake manifold gaskets.
Surging is when the engine changes revs while under or not under load. For example, at idle or full throttle or anywhere in between with no load the engine should seek a constant rev for the throttle setting and not be speeding up and slowing down. An anti-surge spring is usually hooked to the throttle linkage so it is trying to pull the throttle to idle. This tends to prevent wear and play in the linkage and or governer from allowing the engine to surge.
Dave
