Steering shaft pin on WD?
Travis
07-31-2003 22:22:35
Hey all,
I just got through putting a wide front end under a WD for a neighbor and was wondering about the pin that holds the U-joint in the steering shaft to the shaft in the front bolster--Can I use a bolt or pin and just pin it in or should I just try and find the correct pin?? I checked and it is larger than 5/16" and smaller than 3/8" so it may be slim pickin's anyway. The original pin was riveted in(pretty good, too) and I cannot reuse it. If I can use a pin or bolt, should it be a hard or soft one? My Dad says that on the WD we had when I was a kid the bolt in the PTO would break constantly if it was a hard(grade 8) bolt, so he put in an old soft bolt and could go much longer. The hardest we used it was for grinding feed. I am just worried since this is the steering and do not want it to break while the guy is driving down the road or something and get him in an accident. Thanks for any help!
Travis
Dave K (FL)
08-01-2003 18:15:34
 Re: Steering shaft pin on WD? in reply to Travis, 07-31-2003 22:22:35
I forgot to mention if you want the "correct" pins AGCO has them. Problem is those holes in the shaft are often worn some so the roll pins seem to work better.
Dave
Dave K
08-01-2003 18:13:24
I use two roll pins, a large one first and then a small one that fits inside the large one after it is installed. A good AC mechanic suggested this to me and it has held up fine on my WD which I plow and till with.
Dave
Dale(MS)
08-01-2003 04:51:02
Travis, use a roll pin with a roll pin punch. Don't remember the size but its standard. I'd guess its 3/8 in. If I remember right I had to cut to proper length. Dale
