WD MISSES WHEN HOT
DAVE
07-31-2003 19:30:37
I HAVE A 1953 WD 45.THE TRACTOR RUNS FINE WHEN COLD BUT AS IT WARMS UP IT STARTS TO MISS AND EVENTUALLY FOUL THE PLUGS.ANY IDEAS WHAT CAUSEING THIS.
Dave K (FL)
08-01-2003 18:17:37
 Re: WD MISSES WHEN HOT in reply to DAVE, 07-31-2003 19:30:37
Mine did that and it was the condenser.
Dave
Steve in N.J.
08-01-2003 04:10:45
Dave, If it's mag fired, you may have a condenser starting to fail. A quick condenser change might do the trick. If it's distributor fired, as the engine is running see if you can see an arch going from the high tension tower to one of the nuts to the primary ignition wires. Could be a small crack in the coil or carbon track. Couple things to check into for starters...
Steve/B&B Custom Circuits
