WD hyd. pump problem
Jeremy
07-31-2003 15:23:18
I have a '52 WD. early this winter I posted about the hydraulic system being slow. I got several answers from out here and I am looking for more ideas. The system is slow, and not jerky.It was out of adjustment, a tip I got out here. It then worked better until a week ago. It developed a leak somewhere on the pump, not any of the hose fittings leak. Any ideas? By the time I got back to the shed with the tractor all the fluid is out of the resevoir. The rams would not go up or down and are stuck in the up position. I am assuming that it pumped up with air.?!? It took three days for the three point arms to be down on the ground.Did I burn up the pump? Is that possible? I have heard that they are simple plunger type pumps with check balls and springs. Is this true? If I am going to take the pump off I am going to go through it and make the hyd. system finally work properly. I am very mechanicly able, I just need some directions on how to make this pump like new. Any and all input is greatly appreciated. Jeremy Waterloo, IL
wdTom
07-31-2003 18:07:18
 Re: WD hyd. pump problem in reply to Jeremy, 07-31-2003 15:23:18
I would suggest you get yourself a reprint of an AC repair manual for WD/ WD-45. It will make what you are doing a whole lot easier, and you will learn a lot of other usefull stuff about your tractor.
Do you
07-31-2003 21:51:09
 Re: Re: WD hyd. pump problem in reply to wdTom, 07-31-2003 18:07:18
sell manuals? Always needing one and I notice you suggest getting a manual a lot.
wdTom
08-01-2003 18:37:48
 Re: Re: Re: WD hyd. pump problem in reply to Do you, 07-31-2003 21:51:09
No, I don't sell manuals. I recomend them because it is the best way to learn about what your tractor needs to keep it running and to repair it. Many of the questions people ask here could be answered by them reading the manual for their tractor. And they would learn a whole lot more too in the deal. Even for a simple thing a manual can tell you stuff you wouldn't have thought of or guessed. And make you aware of how it is supposed to be.
Same goes for parts books. You can learn a lot reading one, even if you can't order by part number anymore. Just seeing how the parts are arranged can be a real help.
What one pays for manuals is cheap knowledge. If you save the cost of one mistake, or broken part, you have probably saved more than you paid for the set of manuals, to say nothing of the hassle saved.
I got my WD manuals and a couple of others from Kings Books a while ago. I have heard they are not still in business. However somebody must be doing reprints. Even a I&T manual is better than none. The only problem I see with them is they try to cover several models and therefore cannot, in roughly the same no. of pages as AC uses for one tractor model, give as much information about each model.
Now you know why I am always recomending manuals.
