i am new to the WD45 so i am ignorant on alot of common knowledge. currently i am using my grandfathers wonderfully restored 1955 wd45 and am having some complications. that said...someone had replaced the shear pin, probably my grandfather, with a bolt, and i completely stripped all the PTO gears while brushhogging. at this point, i have broken the tractor completely apart, replaced all the gears, put the tractor back together and have two small problems. First, i removed the hand clutch from the torque tube, and thought i had to take it completly apart to remove it from its housing, so i did, and put it back together and back in the housing.
How do I "adjust the hand clutch", is it by the 6 bolts on the clutch inside? or the eternal connection rod or do they just need to be hand tightened? Second, taking on a job that i never imagined and nearly completed, when refilling all the fluids, the gasket on the faceplate of the PTO housing, on the bottom of the tractor, now has a leaky seal. Someone suggested using red silicon? is there anything that will rebond the gasket to the metal faceplate? also, i posted this q in another location on the forum, what is the purpose of the lever near the base of the steering column, below the pto lever? it looks like it goes into the transmission housing. thanks for all the info shawn
