HELP!! WD45 is locked in 1st gear
Jim
07-29-2003 21:01:00
While doing some brushhogging with my wd45 tonight, it locked itself in 1st gear. The shifter does not have a lot of play in it like a broken shifter fork (or ball on the bottom of the shifter, if that is how this one is), but I can't get it out of 1st gear. Anyone have any idea what I might have done and how to fix it? Thanks.
cooper
07-30-2003 05:16:35
 Re: HELP!! WD45 is locked in 1st gear in reply to Jim, 07-29-2003 21:01:00
Sounds like the WD shifter ghost. You will probably have to pop the retaining ring under the shifter boot and remove the shift lever. Look inside with a light to see where your shift lug is. Use a long screwdriver to set it back to nuetral. Place your lever back in. When you have the shifter out. You can build it back up with weld if it's worn. I have rebuilt enough now that I should do it as a side job. Seems to be more rewarding than my DAY job!
wdtom
07-30-2003 17:59:14
 Re: Re: HELP!! WD45 is locked in 1st gear in reply to cooper, 07-30-2003 05:16:35
And while you have the shifter out be carefull not to knock the little keys that keep the shift lever from turning, into the transmission.
