Brush Hog/rotary cutter on an AC B
Tom
07-29-2003 19:01:10
Is it possible to attach a rotary cutter deck to an Allis C. B???? 4' or 5'.... I can find info on adding 3pt hitches, but nothing on horsepower rating and pto or not..
Murphy
07-31-2003 10:15:32
 Re: Brush Hog/rotary cutter on an AC B in reply to Tom, 07-29-2003 19:01:10
I have a '41 Allis B and run a 5 foot BMB brush hog behind it. It will bog down when I run through really thick stuff but otherwise it does fine. My 'hog is also set up to attach to the standard Allis hitch.
Jeremy
07-30-2003 10:49:46
I pull a 4ft trailer type bushhog behind my B all the time. No problem with power. You can pull a 5ft but, you will start running out of power if you mow too low. Or if the weeds are over about 2 ft.
Jay C (MO)
07-30-2003 08:29:34
Can email pictures if you like.
Jay C (MO)
07-30-2003 08:25:53
I have a 48 B with a worksaver 3 point hitch and use a 4 foot brushhog. Worked fine on clearing a field with sapplings up to 1 inch and some a bit larger. Be sure to have an over riding clutch installed on the pto shaft.
