wd45
frito
07-29-2003 13:11:48
What is the difference in engine size between a wd and wd-45
Dave Grubb
07-29-2003 13:55:47
 Re: wd45 in reply to frito, 07-29-2003 13:11:48
201 cu.in. vs 226 cu.in.
L Hud
07-29-2003 13:49:38
Stroke. The 45 has a 4.5 in. stroke. The WD has a 4 in. stroke.Other than that they are basicly the same engine.
wdTom
07-29-2003 17:25:17
 Re: Re: wd45 in reply to L Hud, 07-29-2003 13:49:38
Well, yes, they are basically the same engine, I agree, the 45 does have the power crater pistons that help it put out 25% more power than the WD. 43.something vs. 34.6 for the WD.
john
07-30-2003 05:05:11
 Re: Re: Re: wd45 in reply to wdTom, 07-29-2003 17:25:17
the blocks are different the 45 has a wider jounals for the mains
wdTom
07-30-2003 18:02:03
 Re: Re: Re: Re: wd45 in reply to john, 07-30-2003 05:05:11
Could you explain that a bit, I thought you could take a 45 crank and put it into a WD or WC block, but not if the bearings are different??
