12 volt conversion pulley needed
Larry Ross
07-29-2003 07:20:49
I am converting a 1950 Allis wd to 12volt, but the alternator pulley is narrower than the tractor belt. Anyone know of a pulley supplier?
Joe
07-29-2003 14:11:24
 Re: 12 volt conversion pulley needed in reply to Larry Ross, 07-29-2003 07:20:49
First Of All What Alternator Are You Using? If It Is A Delco Remy 10 SI The Pulley You Need Is Vintique Inc. Part # VIN-A-10130-ALT Available From Parr Automotive Inc. 4933N. W. 10 Th Street
Oklahoma City, Oklahoma 73127
Rod (NH)
07-29-2003 21:32:39
 Re: Re: 12 volt conversion pulley needed in reply to Joe, 07-29-2003 14:11:24
Hi Joe,
Thanks for the source for that pulley. You can even buy it on-line here.
third party image Rod
Steve in N.J.
07-29-2003 11:23:50
Larry, Just install the OEM generator pulley on the alternator. Same shaft size. It'll work fine....Icks-nay the keyway....
Steve/B&B Custom Circuits
Duey (IA)
07-29-2003 11:12:04
Larry,
The old pully from the 6 volt gen will fit.....just forget the key and tighten it in place. An impact works best. Duey
Dave Grubb
07-29-2003 08:41:39
You can get them from Genesee Products, I think they have an ad on this site.
