WD spark plugs
Denny
07-27-2003 11:58:01
WD began missing and I found that the plugs from the front two cylinders had the prongs smashed down against the body of the plug and twisted off to the side. It looked like something had been hitting them. Rear cylinder plugs were o.k. Any thoughts as to what is going on? None of my "tractor buddies" can explain it.
Steve in N.J.
07-27-2003 19:26:26
 Re: WD spark plugs in reply to Denny, 07-27-2003 11:58:01
Denny, Sounds like something got in the cylinders to damage the plugs. Sometimes a chunk of carbon can break off and close the spark plug gap, but I don't know about twisting it. Is it possible that you have the pistons in those two cylinders coming apart and the pieces are mashing the two front plugs? If it happens again after you replace those two front plugs, I'd pull the head and find out what's goin' on in there...
Steve/B&B Custom Circuits
Denny
07-29-2003 13:57:38
 Re: Re: WD spark plugs in reply to Steve in N.J., 07-27-2003 19:26:26
Steve,
Thanks!! I pulled each front plug individually and turned it over a few times hoping anything in there would blow out. Put new plugs in and so far everything is o.k.
Steve in N.J.
07-29-2003 20:02:59
 Re: Re: Re: WD spark plugs in reply to Denny, 07-29-2003 13:57:38
Denny, Great to hear! Hopefully that'll take care of yer' problem..... Have fun!
