Model B won't start
Mike
07-26-2003 19:42:36
I have a 47 B it has been sitting for a couple of years,ran pretty well when parked. It won't start now. I've been reading alot of the items on this forum,and have tried a few of the things mentioned It has a good spark, I replaced the points and condenser,plugs and wires.When I pull out a plug it smells of gas. I rebuilt the carb,a zenith but the IT manual does't give any adjustment specs for it.Any help with a place to start would be much appreciated.Thanks to everybody on this forum for all your help.
Tyler(WA)
07-26-2003 23:04:05
 Re: Model B won't start in reply to Mike, 07-26-2003 19:42:36
I can't tell you how many times an engine that wouldn't start will fire right up with fresh gas. Stale fuel is no fuel.
Ken/Wa
07-26-2003 21:11:52
Make sure you drain all of the old gas out. Water builds up in the tank. I would shoot a little starting fluid to it, which might tell if it was a fuel problem. Drain the bottom of the carb also. I go through a cough and sput session every spring after I have had the tractor sitting. That is why you are supposed to do certain thigs to store your tractor. These little B's are great, but do not like to drink water.
Rod (NH)
07-26-2003 20:12:57
Hi Mike,
"Normal" setting for the idle mixture screw on that Zenith is 1-1/2 turns out from seat according to AC in the B manual.
third party image Rod
tony c
07-27-2003 18:41:50
 Re: Re: Model B won't start in reply to Rod (NH), 07-26-2003 20:12:57
try new plugs and new gas. turn gas on to fill carb and bowl, turn gas off and try starting. if it starts turn gas on if it floods out your float is not set proper or it may be bad. I have seen a bad condensor cause a similar problem to.
