6volt - 12 volt conversion
cooper
07-26-2003 19:09:25
Converting to 12 volts on a WD45, could a guy use a 12volt generator from a WD45 diesel or any other 12volt Allis generator? 12 volts is 12 volts isn't it?
Steve in N.J.
07-27-2003 19:32:53
 Re: 6volt - 12 volt conversion in reply to cooper, 07-26-2003 19:09:25
Coop, We offer a 12V conversion for all AC machines. Drop us a line if interested....
Steve/B&B Custom Circuits
steve
07-26-2003 19:33:19
you can use any generator. remember a generator needs a voltage regulator. it is more common to install a alternator from a mid 1975-85 chevy with an internal voltage regulator. less cost and simple unless someone is giving you the generator. If you need additional information, just ask.
cooper
07-26-2003 20:01:37
 Re: Re: 6volt - 12 volt conversion in reply to steve, 07-26-2003 19:33:19
To keep a stock look to a tractor, a 12v generator ought to do the trick.
steve
07-27-2003 20:05:13
 Re: Re: Re: 6volt - 12 volt conversion in reply to cooper, 07-26-2003 20:01:37
I put a 12 volt generator, and voltage regulator on my IB. ALso have a ford starter solenoid and a starter button for it. I have a schematic if you need one. send me a line.
