12 V positive Gnd/ change to 12v Negative GND
Don
07-25-2003 10:39:43
Hello a friend of mine has a 69 D15 i think its a a 69, maybe 66.... anyway it has a bad generator, 230 bucks for a rebuilt one..... .
and its a positive GND, can I change this to a Neg GND system, so i can use a GM Alternator, if so HOW do i do it, what do i need to do to change it over????? ?//// please send me the info.... thanks My email----- -- > [email protected]
steve
07-25-2003 18:52:02
 Re: 12 V positive Gnd/ change to 12v Negative GND in reply to Don, 07-25-2003 10:39:43
Don, chekc your e-mail. i sent a diagram of the wiring. the delco is the most common alternator to use. just make sure it is built after 1975 and has the internal voltage regulator. you need a resistor 10 ohm, 10 watt in one of the alternator lines. this makes a small voltage drop and makes the alternator "kick in" at lower RPM. you can get it at Radio shack for $1. it is brwon and 3 inches long, 1/4 inch square. Make sure the wire goes to a switch or key to shut off power when not running so you dont drain the battery. if you need more info, write me.
Attention Dave Wis??????
07-25-2003 18:31:46
thanks Dave..... could i just use a Coil and a ballist from a newer 12V system?
Dave Wis
07-25-2003 17:33:08
Reverse the cables on the battery and the two small wires on the coil. Lights and starter are good as is. It will probably run with the coil as is but alot of them will run rough with the coil polarity backwards. The coil terminal going to the distributor should be the same polarity (+ or -) as the battery terminal going to ground. Hope this helps.
Doug in OR
07-25-2003 18:41:16
 Re: Re: 12 V positive Gnd/ change to 12v Negative in reply to Dave Wis, 07-25-2003 17:33:08
He needs to swap ammeter connections also. It won't hurt if he doesn't, just that the ammeter will read backwards. And you correctly did not mention anything about the ballast resistor. Since this is already a 12 volt system, no changes are needed here. BTW, good move changing to an alternator. They are less expensive and easier to maintain than a generator.
Don
07-25-2003 18:29:51
Dave..... .. can i just use a newer 12V coil and add a ballast resistor from an Dodge?
Dave Wis
07-25-2003 20:58:06
 Re: Re: Re: 12 V positive Gnd/ change to 12v Nega in reply to Don, 07-25-2003 18:29:51
As stated by others, since you already have a 12 volt system, your coil and resistor are ok as is. If, for whatever reason you need or want to put on a new coil, you can use one with an internal resistor, one less part. And, yes, I did forget to say you need to reverse the leads on the ammeter.
