WD45 Final Drives
Nate in IL
07-24-2003 20:05:41
Hi! Is there a trick to "draining" the final drives on a WD45? I didn't see a drain plug so I tried to drop the pan. It won't come off with the tractor's wheel on. Am I missing something or do I need to take a rear wheel off before I can change the final drive lube?
Thanks,
Nate
Dave K
07-26-2003 10:33:04
 Re: WD45 Final Drives in reply to Nate in IL, 07-24-2003 20:05:41
You gotta run the rear wheels out as wide as they go. On my WD I then need to tilt the "pans" slightly upwards(towards the axels) and they will drop out. When you put them back on I would suggest you only fill them about halfway with gear oil, otherwise it's gonna run all over. Then after installed fill to the plug hole.
Dave
John (C-IL)
07-25-2003 05:32:08
Slide, power adjust, the rear wheels out to a wide position and it will be real easy. John
