WC BRAKES
Don Ober
07-22-2003 17:30:03
I am trying to change the brake lining on my WC,and am having trouble getting the shaft out ,duz it just slid out our is there a pin holding it,don`t want to break anything THANKS Don
Joe M
07-23-2003 18:59:00
 Re: WC BRAKES in reply to Don Ober, 07-22-2003 17:30:03
What thickness lining do you use,I really need to do mine if I can find the material
xavier
07-22-2003 17:54:11
Don, you need to drive the pivit shaft out towards the tire. Before you do that loosen the adjusting nut, and push the threaded rod out of the hub. The shaft is probably "stuck" inside the hub. Get a big hammer and suitable drift punch, and start swinging. I have removed several this way. Keep in mind that there is a woodruff,(halfmoon), key in the shaft. It will start to show after you move the shaft an inch or two.
