Simple IB Question
Greg Lasher
04-01-1999 07:54:23
What is the width and weight of an IB. I don't have any books on A/C's and bought this tractor sight unseen. I'd like to take my small trailer if I could.....so please let me know what I'm up against. How many IB's were built? Does the sheet metal interchange with a B, anything else interchangable?
e mail Greg at [email protected]
THANK YOU
Doug Morrow
04-05-1999 10:04:43
 Re: Simple IB Question in reply to Greg Lasher, 04-01-1999 07:54:23
If you haven't already moved it, just be careful. The first time I moved my AC B, I loaded it on a 5X10 trailer that I was assured had the capacity to haul it. Two miles down the road I realized something was very wrong and checking found the axle bent to the point that the tire was rubbing against the frame. Fortunately, I was able to limp home, but the tire was ruined and the trailer not much better off. I hate to think what could have happened on the open road. As it turned out the rated capacity of the axle was much less than I had been told and about 500 lbs less than the weight of the tractor. I now have overkill, with two 4000 lbs rated capacity axles on the trailer I use to haul equipment.
Chances R
04-01-1999 15:31:21
I just bought one myself. Im taking my 5 x 8 trailer to get it. it is 53" wide im told. I believe it weighs between 2000 and 2500 lbs. i have been told anywhere fro 2000 to 8000 IB's have been made. i think the hood and grill are the same but fenders and seat are different.this will be my first allis chalmers tractor. i sure am lookin forward to getting mine home!!!!! good luck
Ed Wieging
04-01-1999 15:53:04
 Re: Re: Simple IB Question in reply to Chances R, 04-01-1999 15:31:21
IB model weight is around 3000 lbs. and closer to 10.5 ft long the only way this tractor will fit on a 5x8 trailer is if it was in pieces. Have fun hauling it home. Ed Wieging
Chances R
04-01-1999 17:25:54
 Re: Re: Re: Simple IB Question in reply to Ed Wieging, 04-01-1999 15:53:04
i had the owner of the tractor go out and measure it.
Dennis H.
04-01-1999 18:46:44
 Re: Re: Re: Re: Simple IB Question in reply to Chances R, 04-01-1999 17:25:54
The front axle on an Industrial is set back farther than the B and the overall length is the same, but it will fit on a shorter trailer. The extra weight is from the massive metal frame that surrounds the whole front of the tractor.
