WC Engine swap
Don
07-18-2003 03:50:18
I have a 43 Wc, and a D-17/combine motor. is it better to put the bigger crank in the wc block? or just drop the d-17 motor in the chassis? thanks, don
No Problem
07-23-2003 07:56:58
 Re: WC Engine swap in reply to Don, 07-18-2003 03:50:18
Putting the combine motor in the WC is no problem whatsoever. Only thing you will have to do is make a plate to cover the fuel pump hole in the side of the block. We've done a bunch of times on pulling tractors.
And don't worry about the drive train. They'll hold at least 90 hp or better.
Don
07-20-2003 05:20:02
Thanks for your input!! should be a good winter project. Don
Sid
07-19-2003 07:19:37
I would be concerned about the strain that much extra HP would put on the drive train and chassis.
H.B.
07-18-2003 19:47:16
Don, I believe the D17 combine has bigger mains than the WC and the 45. H.B.
wdTom
07-18-2003 17:22:10
I would put the whole engine in. Save the WC engine, store it carefully with lots of clean oil in it, bar it over once or twice a year. You may someday want to return the WC to original. Is it old enough to be unstyled? If so I would definately keep the WC engine around, even though you will like all the power of the D-17.
steve
07-18-2003 07:23:04
ues the D17 motor. more horsepower, bigger pistons and more improvements. will take a littel more time to install, but worth it in the long run.
