Where can you find this?
Garry
07-16-2003 10:02:38
i have been looking all over town for a piece of tubing to replace the tubing in the rocker arm of my AC WC. This is the metal tubing that carries the oil into the rocker arm. It is about 1/16 inch in diameter. No one in town seems to carry that small size tubing. I also need the faret?? to connect the nuts on the tubing.Can anyone tell me where to find this. thanks
Garry
07-17-2003 11:50:34
 Re: Where can you find this? in reply to Garry, 07-16-2003 10:02:38
thanks folks for the replies. I have found some of the wire based on the replies. Sure appreciate this board and all the help I get.
Doesn`t need to be cooper
07-16-2003 20:16:56
Steel brake, line any auto parts house.
Steve in N.J.
07-16-2003 19:53:26
Garry, We have 1/8" copper tube in a small roll we sell. We have the fittings also if ya need em'. Drop us a line if interested.....
Steve/B&B Custom Circuits
wdTom
07-16-2003 18:08:28
That should be the same as for a WD. The factory part no. for the tube is 206861, also uses two of 912367sleeve and two 912064 nut. And one elbow910129, says incl. nut and sleeve above. And one connector 910126. Might be available from ACCO if you have a dealer in area. Or call Sandy Lake. Ask them to check on part nos for a WC. As I said I would thenk they would be the same, same engine.
Steve
07-16-2003 18:01:37
Garry: If the tube is like my C you can use an oil pressure installation kit from NAPA or Carquest. The nice thing is you get some fittings and ferrules in the kit. You may have to grind them a little or put a spacer in behind it but it worked for me. steve
Garry
07-17-2003 11:16:58
 Re: Re: Where can you find this? in reply to Steve, 07-16-2003 18:01:37
Steve, thanks for the info. I found the tubing at Discount Auto in a oil preasure installation kit as you stated.
Rod (NH)
07-16-2003 12:25:04
Hi Garry,
If your WC is the same as my B, that tubing should be 1/8" OD copper. That makes the ID about 1/16". You might want to check some auto parts suppliers and ask for copper tubing to hook up mechanical oil pressure gages. They use that size. You will find a lot of nylon tubing for that purpose but I have also seen copper. It's a kit that comes with some adapters and the correct size ferrules.
The tubing is also referred to as ACR tubing. Thats for air conditioning and refrigeration tube. It is soft copper that is flexible. If you can't find that 1/8" OD size locally, this site is an on-line source. If you poke around on the site, they also can supply the correct size ferrules (also called sleeves).
If you continue to have difficulty finding this tubing it may be tempting to replace it with more readily available 1/4" OD tubing. I do NOT recommend that. If your WC is like my B, that small tubing acts as a restrictor that meters oil flow to the rocker assembly (and the governor also on my B). If you decrease the flow resistance of the tubing by increasing the size greater than the original design, you may increase oil flow to the head area and decrease it to the engine lower end bearings. That's not a good thing IMO.
third party image Rod
