Removing steering wheel on CA
Craig
07-14-2003 10:12:47
I've bought a replacement steering wheel for my CA and am trying to remove the bolt that retains the steering wheel. After soaking it with penetrating oil, I've been able to loosen it somewhat, but I cant seem to get it to retract. I am beginning to wonder if there is some sort of pin that I need to check or whether I've likely got a stripped bolt. I checked the connection on the steering column in front of the tool box and it doesn't seem to be slipping there. I can still turn the steering wheel and it moves the front wheels as expected. I noticed that I get some front-to-back flexing in the steering column, but that seems to be due to the method of connection around the tool box. Am I missing something?
Steve in N.J.
07-14-2003 18:59:53
 Re: Removing steering wheel on CA in reply to Craig, 07-14-2003 10:12:47
Craig, The steering wheel on my B was held on with an acorn nut as well. That was a bugger to get off also, till I put some heat to it like Dick mentioned. I then used a puller to pull the wheel off. When I reassembled it, I dressed the threads with anti-seize compound so in case I ever had to remove the steering wheel again, it shouldn't be a big task as the first time...
Steve/B&B Custom Circuits
Dick L
07-14-2003 12:42:05
It should be held on with an acorn nut. That is a nut with a round hump over the threads. If someone has replaced it with a regular burr on hex nut it is probably rusted fast. Get it red hot and it should turn off. Another if is, if the stripped threads and if they seem to be stripped slightly you might save the shaft by cutting or grinding the nut off, making sure you do not further damage the remaining threads.
