New AC C owner, need distributor help.
Robert
07-12-2003 13:51:52
Hello, Great board and from what I see great group of people willing to help. I am a new AC owner, purchased a 42 C, it has an alternator, 12 volt system. It was running until recently here is a few of my problems:
-There is a Case Co. mag connected to my governor unit, this was an old mag that has the guts out of it. Connected to the mag is a distributor setup that is well worn and points are shot. I want to replace the Case co stuff with a distributor that connects straight to the govenor unit.
A. Is this possible? B. Can anyone help me out with part numbers? (I am looking for a distributor that has a cap I can buy a auto store or at least find new from a tractor specialty store)
Thanks in advance
Robert in Moline Illinois!
steve
07-16-2003 16:23:11
 Re: New AC C owner, need distributor help. in reply to Robert, 07-12-2003 13:51:52
Bob, i can get you started. The C originally came with a magnito. AFter 1950 they changed the model to a CA. It and the B were converted to distributor with coil and point. You can make this conversion if you have the adaptor that goes inside. You would be further ahead to go to a used tractor (junk yard) and try to ge one off a CA or a newer B. The mag and distributor were not made by ALLIS. they wer Fairbanks, Delco, etc, so you can possibly see the same distributor on a Case of IH, etc. You can also go to NAPA and ask them to look in their book. They will have the point, cap, coil, etc, but probably not the entire unit.
