No Spark WD45
GAry Knox
07-11-2003 18:15:20
I have a WD45 that has spark to the distributor but I can't get a spark from the plugs. The wires are good, new plugs, new battery, new rotor, new distr cap. What do I try next???
Steve in N.J.
07-14-2003 04:55:17
 Re: No Spark WD45 in reply to GAry Knox, 07-11-2003 18:15:20
Gary, If you have spark at the points in the distributor, and not at the plugs, it's grounding out either in the cap, contact plate, junction block, wires or possibly a faulty condenser. Could even possibly be a bad cap even though new. Every once in a while we'll come across a bad cap with a bad high tension tower. Make sure you're not using resistor wires either. That's a no-no with these particular ignition systems. We build the correct wires for AC machines if you find it's a wire problem. HTH Good Luck! You'll find the problem.
Steve/B&B Custom Circuits
Dan E (AL)
07-12-2003 21:11:03
Try putting the old distributor cap and rotor back on. Could be the wrong one. I have had parts out of the box be the wrong ones before even though the #'s on the box were the correct ones. Napa was where I had this problem. Sometimes the simple things are what get ya.
John-in-Va
07-12-2003 17:31:32
Hmmmmm mm..... Has the distributor been removed? Does she spark when the rotor hits a terminal?
John-in-Va
07-12-2003 06:21:45
It may be that the coil is not putting out enough force to get a spark at the plugs. Do the wires spark when shorted to the block?
Gary
07-12-2003 06:26:40
 Re: Re: No Spark WD45 in reply to John-in-Va, 07-12-2003 06:21:45
No spark to the block. The coil is new and works fine on another tractor. Thanks for your repy.
