WD-45 Leaking
Scott E.
07-11-2003 06:35:18
My tractor is leaking hydraulic fluid at the pump. How much of a task is it to rebuild the pump and hold position valve? Where can I get the rebuild kit? Also need to rebuild the lift arm cylinders too.
Dave Grubb
07-11-2003 11:30:18
 Re: WD-45 Leaking in reply to Scott E., 07-11-2003 06:35:18
If the leak is between the hold valve body and the pump body you can just replace the o-ring between the hold valve body and the pump body, easy to do. There is a gasket between the pump body and the reservoir casting that you can replace, a little more difficult to do. Sandy Lake Implement can rebuild the hold valve or pump and control or both for you.
