Tractomotive oil press.
Butch
07-08-2003 18:36:36
I have an old TL10 that I use to push manure,I use it every day, 365 days a year. I have been reading about the paper filters not holding press. The last time I changed the filter the new one was paper and the one before looked like cotton packed inside for a filter media. Don`t know if I had a pressure change or not because the gauge has not worked for years. Can someone tell me why the filter has to be restrictive? Is this just to hold pressure at the gauge? I always thought that clearance in the bearings and the oil pump trying to shove oil through them is want made the pressure. Thanks
steve
07-08-2003 19:05:44
 Re: Tractomotive oil press. in reply to Butch, 07-08-2003 18:36:36
Butch, i dont know which motor was in the TL. The low pressure filter problem you are reading about is a couple of the smaller old ALLIS motors. THe filter is an add on type thing. They bleed 15% of the total volume away from the lubricationi circuit, run it thru a filter and then dump that to sump. If you open the filter (less restriction) you loose too much to sump. These are not like a newer auto type motor where 100% of the oil is filtered then goes to the bearings. That type you would want low restriction in the filter.
Butch
07-09-2003 05:40:14
 Re: Re: Tractomotive oil press. in reply to steve, 07-08-2003 19:05:44
Thanks Steve, that makes sense. I will change the filter again before I use it today. The motor is a WC, so I am told. When I got it the engine was stuck so I pulled the head and go it free. I noticed that the pistons were not coming all the way up, an old Allis guy told me someone had put in WD pistons but left the WC crank. You would think that it would be hard to start but it fires up in all weather from 100 to 20 below. Thanks again, you might have saved my motor.
steve
07-09-2003 20:26:15
 Re: Re: Re: Tractomotive oil press. in reply to Butch, 07-09-2003 05:40:14
i dont know a lot about the WC -Wd motors, but i dont think the pistons come up to the top of the deck on them. These old motors only have about 6 to 1 compression. If the piston is almost 1/2 inch from the top, that could be normal.
Larry from MD
07-09-2003 17:21:44
We had a TL10 for 20 years, and it had a WD engine in it.I overhauled the whole engine in 74 and it was all WD.
Butch
07-10-2003 04:59:06
 Re: Re: Re: Re: Tractomotive oil press. in reply to Larry from MD, 07-09-2003 17:21:44
It could very well be a WD engine all the way . I have never had a WD or WC so I wouldn`t know the difference,maybe the piston thing is normal. At any rate, I did get a cotton oil filter before I used it yesterday.
