Allis chalmers d-17 horse power/ brakes
cody
07-08-2003 17:51:38
How many horsepower is a 1966 d-17? we guess around 50 but we are not sure. to do a brake job on one of these do you need to pull the wheels?
Garri
07-10-2003 19:44:43
 Re: allis chalmers d-17 horse power/ brakes in reply to cody, 07-08-2003 17:51:38
On a series III or IV you do have to pull the wheels off as well as the final drive (axle) to replace the brakes. It can be a chore.
Dave/MI
07-09-2003 06:57:37
The information I have collected shows Drawbar HP at 48.64 and PTO HP at 52.7.
My service manual has a good section on brakes. It might be a good idea to buy one. According to the manual you don't have to remove the final drive assembly unless you plan on removing the brake drum. The brake shoes can be changed by removing the access cover. As a side note - you will need a brake drum puller to remove the brake drum from the pinion shaft. (At least that's what the manual shows)
Hope this helps!
Dave/MI
JMS/MN
07-08-2003 23:22:25
I think it's about 53 hp. It would have disc/drum brakes, and you need to pull the wheels and axles to renew them. Works well to remove the wheels and use a cherry picker or hoist to support the axle housing.
