Help please
D17 PTO shaft removal question
Dave
07-08-2003 05:50:56
I have a 58 D17 with a bent PTO shaft. The bend is causing the seal to fail and constantly drip. I don't feel any movement up or down or right or left so I don't think the bearing is causing the wobble. The shaft may even have a slight twist.
The service manual has a section on removing the PTO and gear which requires the removal of a cover plate at the bottom of the torque housing, removing the PTO shifter lever assembly, oil pump assembly and gears.
A friend told me I may be able to just engage the PTO lever, remove the three bearing retainer bolts and remove the shaft. This sounds much easier than removing the cover plate like the manual shows.
Has anyone removed a PTO shaft on a D17?
My AGCO dealer is showing a new PTO shaft #70231938 @ $326.0
I looked on valu-built.com and they show the exact same part number @ $109.99???? Has anyone ordered parts from valu-built? Are they used parts?
Thanks for your help!
Dave
(Michigan)
JMS/MN
07-08-2003 23:26:31
 Re: Help please - D17 PTO shaft removal question in reply to Dave, 07-08-2003 05:50:56
1972, the first year I farmed, I broke off the pto shaft when the 80S mower drive chain broke, and wrapped around the shaft. As I remember, to replace the shaft, I just took off three bolts at the rear casting, and pulled the shaft out.
