AC 7000 problem
JimL
07-07-2003 14:44:46
I have a 7000 AC that leaks around the rear injector. I had all the injectors rebuild about ten hours ago. It runs perfect without any miss. It looks like it is motor oil leaking around the number 6 injector. It could be diesel but it looks like oil to me. I just put on a new valve cover gasket because I thought it could be that leaking behide the injector. It wasn't.
Someone told me to pull the injector and have it tested for leaks, but the diesel shop is a two hour drive. What can it be? Help.
JimL
Farmer Gene (WI)
07-08-2003 19:20:06
 Re: AC 7000 problem in reply to JimL, 07-07-2003 14:44:46
Well if it was a 190 I would say it is the copper washer that seals the injector, the 7000 uses 0 rings, maybe when the injectors were installed one of the 0 rings got rolled or got dirt behind it, I would call where you got them rebuilt and explain the problem.
JimL
07-09-2003 05:27:34
 Re: Re: AC 7000 problem in reply to Farmer Gene (WI), 07-08-2003 19:20:06
Thanks for your help.
