Allis B Tires
JC
07-07-2003 12:45:24
Time to replace the rear tires on my B. I now use
9.5x24 but they look small. Does anyone use 11.2
tires and how do they fit on the rims. Best I can
tell with the tires on, the rims are 9" wide. It
should have a 10" rim for 11.2 tires to be right.
Thanks for any information and opinions.
wr
08-10-2004 20:16:44
 Re: Allis B Tires in reply to JC, 07-07-2003 12:45:24
Does anyone have a recommendation on the rim size for 11.2 x 24 tires?
10" is recommended, but 9" is still okay.
Does 10" seem a little wide?
When I got my C it had 12.4's mounted on 9" rims.
The rims and one tire was no good.
John P. Martine
07-08-2003 11:30:21
It sounds like your changing the tires for aesthetics. If that�s the case, what kind of condition are the 9� tires in? I am in need of a set of rear tires and $$$ are short. Where are you located.--JPM
JC
07-08-2003 20:21:59
 Re: Re: Allis B Tires in reply to John P. Martine, 07-08-2003 11:30:21
Sorry I'm using the tires on the front of my 4x4
tractor. I ordered 9.5 BFG from Miller Tire today
Decided to stick with the smaller tires to save
on cost and shipping. Thanks for all the opinions.
Dick L
07-07-2003 12:58:22
I don't know how or what you use the tractor for but remember that if you go up to that large of a tire the speed in each gear will increase. If you use it in the field the traction will be better but will seem to have less power pulling a heavy load.
Kip [UT]
07-08-2003 08:23:40
 Re: Re: Allis B Tires in reply to Dick L, 07-07-2003 12:58:22
The 11.2s will work just fine. This is the same size as the old 10-24s. I have 9.5s on my B & one C & 11.2s on two other Cs. I do like the larger tires better.
Bryan Smith
07-08-2003 13:22:51
 Re: Re: Re: Allis B Tires in reply to Kip [UT], 07-08-2003 08:23:40
I have 11.2's on my 1949 B and they look just right. I have another B with a 12.4 on it and that looks too big, and I agree that a 9.5 looks small on the tractor.
Then again I have 13.6's (I think that's right - they are bigger than the 12.4's) on my CA with fluid in them (did that for more speed in the field - it worked to some degree ... and didn't hurt the power much at all).
A few extra inches of height won't make much difference in speed, but it will add a little.
