No oil pressure wd45
Jim in Michigan
07-06-2003 20:58:10
Checked the oil on the WD45 yesterday before baling and it looked crappy., decided to change it,,drained it out, replaced it with clean new oil..now there is zero oil pressure and it sounds like a possible knock,,it was fine before the oil change...any ideas???Jim
Dave K
07-07-2003 08:20:53
 Re: no oil pressure wd45 in reply to Jim in Michigan, 07-06-2003 20:58:10
Also, if you changed the filter make sure the center tube on the filter base did not come off with the old filter. The Wd never reads much pressure at the gage but should read somthing.
Dave
AZ Jack
07-06-2003 22:10:23
First thought is did you change the filter-there has been some discussion lately on using the proper filter. Some replacement filters are using paper pleated instead of the cotton original filters and are not allowing enough back pressure.
Just something to consider--Jack
