Company Logo (800) 853-2651 Shop Now
Re: CA pto hand clutch
papa
07-04-2003 16:29:31
your hand clutch has nothing to do with your right wheel it is the same as your foot cluutch in as far as operating the tractor if it dont nothing will work . you can set them up by removing houseing cover n take out shims there are three sets of shims .010 n .020 thick . take them out of one plce n put them behind the bolt head .
Gene[IN]
07-05-2003 07:18:16
 Re: Re: CA pto hand clutch in reply to papa, 07-04-2003 16:29:31
This is a ca not a wd or wd45. The ca has a dry clutch that is located in the right axel housing. When the hand lever is pulled it separates the axel and stops forward motion and lets the pto and hyd. Pump continue to run.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: John Deere Tires And Rims, (1) Set Of Duals, Axle Mounting Hubs, Tire Size 18.4-38, Units Are Off Of A John Deere 4440 Tractor, Year Is Unknown [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
