Model C govenor problems
Richard Leport
07-02-2003 20:20:50
I need help with a 49 Allis Chalmers model C. I recently removed the magneto to replace the coil. I reassembled the magneto and put it back on the engine. The engine started right up and seemed to run fine but the govenor keeps stopping the engine. What did I do wrong? Is it the timing? Can I disable the govenor?
Duey (IA)
07-04-2003 17:13:31
 Re: Model C govenor problems in reply to Richard Leport, 07-02-2003 20:20:50
Richard,
What do you mean by stopping the engine? Slowing it down or actually shutting it off? How long does it run?
If you post more info, maybe someone here can figure it out. Duey
Richard Leport
07-05-2003 08:35:15
 Re: Re: Model C govenor problems in reply to Duey (IA), 07-04-2003 17:13:31
The engine starts fine then after 3 minutes the govenor starts slowing the engine, within 1 minute after that the govenor kills the engine.
Duey (IA)
07-05-2003 19:49:12
 Re: Re: Re: Model C govenor problems in reply to Richard Leport, 07-05-2003 08:35:15
Richard,
It ain't the governor giving you the problem. My guess is the condensor or the coil IF you are getting full flow of fuel from the tank. 1. Open the drain plug on the bottom of the carb and let it run for 30 seconds.....if it slowes...remove the sediment bowl assembly from the tank and clean the inlet opening....rust will plug this opening and cause what you describe...2. If the fuel is OK then install a new condensor..3. If the problem persists change the coil. Duey
