Allis
C
Dan
07-02-2003 12:31:05
No spark at plugs , and Im getting a very weak yellow spark at the coil, points and condensor are clean , good wires and new spark plugs. do you think the coil is to weak to generate enough voltage? Tractor has been sitting for many years in a barn but is very clean.
Thanks in advance - Dan
wdTom
07-03-2003 17:57:44
 Re: Allis - C in reply to Dan, 07-02-2003 12:31:05
Check, clean, replace points and condenser. Check wire to coil (primary) and to distributor. Could be partially broken or weak from mice eating insulation. Saw this on a friends Farmall H. The coil probably ages better than the condenser and points. Points can get corrosion on them, usually don't work then though. Check all connections that have to do with power to the coil too including ignition switch.
