Thanks for the info Phil. Yes, it is an ex-ag cat with the turboed 6000 engine and wet deck. Engine clutch in oil and power assist to track clutches and brakes. The current set up is an after market one, not factory but it is very professionally done. I am thinking of using the current pump if the rotation is correct as the increased speed from running off the engine will only increase the flow, not the pressure, right? My current problem is slow reaction time with the blade as I usually like to idle down the tractor when I do grading, etc so the pump is way below 540 RPM. Then there is the clutch problem..... no blade use if clutch is disengaged since the PTO needs clutch engaged to work. Any pics would be appreciated as are your comments. Engine in this baby is as sweet as they get. One small squirt of ether at Zero degrees in winter is all she takes. 20-30 degrees she needs nothing. In this weather it will start like it was shut down a minute ago. No glo plugs, no engine heater. Just me and Allis. I love her of course. Thanks again Rick I will try to get a pic but she is not at home for a week or two so will be difficult. She is a bit over powered for the weight too. Breaks my heart.hehehe
