Interchangeable front-end parts for WD
gwalker
07-01-2003 09:19:23
Does any other AC model's wide front end fit on a WD?
JMS/MN
07-02-2003 00:08:00
 Re: interchangeable front-end parts for WD in reply to gwalker, 07-01-2003 09:19:23
The wide front on the WD and WD45 interchange with each other, and also fit on the WC, although they were not made for the WC.
Eldon
07-01-2003 19:09:38
Early model WD45s had the same 3 bolt mounting plate. You can use the 4 bolt from the later WD45s but will have to change out the pedestal as well. A model WC pedestal might fit, but I don't think you want to know the going price for a WC wide front...
JMS/MN
07-03-2003 23:17:39
 Re: Re: interchangeable front-end parts for WD in reply to Eldon, 07-01-2003 19:09:38
Eldon, I think you are confusing the poster talking about 3 and 4 bolt mounting plates. Those are two different plates on the front of the cast pedestal. My 1953 WD45 has the 3 bolt plate like the WD, and maybe later WD45s had the 4 bolt. But to switch front ends, you need to switch the entire unit, pedestal included. WC wide front was a non-adjustable unit, and since the frame members are identical to WD, WD45, you could switch entire units, although it would not be factory original. With so few WC equipped with wide front, I'm sure the price for an original would be quite high, but the WD, WD45 units would fit.
