AC HD-3
mark k.
06-30-2003 07:19:18
I have a hd-3 loader with steering problems, when i pull the left clutch the loader stops completly, the left side had no drive only the right side seems to work, i tried to adjust the clutch but it seem to be adjusted out all the way? the unit was apart not long ago and i was told the clutches still had 'life in them'?
any suggestions??
Hyperpack
06-30-2003 11:12:42
 Re: AC HD-3 in reply to mark k., 06-30-2003 07:19:18
Check the little pin that holds the splined shaft from sliding over and disengaging from the inner clutch hub, This pin is held in by a spring band that is around the inner clutch hub, the shaft is the splined shaft that couples the clutch to the ring gear carrier.
There are three shallow holes in the splined shaft the pin should be in the center hole the other two are to used with a bar to slide the shaft in and out of the clutch hub.
Hope this helps Hyperpack
