Oil Leak, but not the Pan
Les Lynch
06-29-2003 20:09:30
I've got a leak coming from the bottom of the "half round" bell housing plate that face the rear of the oil pan. No leak is evident from the rear main and no oil is on the flywheel. I appears to be coming from between the flywheel and the transmission. This engine serial # is after the end of the "wick" that lubricated the the pressure plate bearing....so this shouldn't be the problem.
Any ideas are much appreciated. Les Lynch
Dave Grubb
06-30-2003 08:20:03
 Re: Oil Leak, but not the Pan in reply to Les Lynch, 06-29-2003 20:09:30
Might be from the hydraulic reservoir. There is a seal on the shaft at the input face of the torque tube/hydraulic reservoir. You could try lowering the the hydraulic fluid level some and see if the leak is less.
