Need parts for a WD45
Jr64
06-29-2003 19:52:16
I need a set of power adjust rims, engine block, crankshaft and balancer for my WD45. The rest of the tractor is good and the sleeves and pistons are not very old. Any help would be appreciated.
Max(ia)
06-30-2003 06:19:13
 Re: Need parts for a WD45 in reply to Jr64, 06-29-2003 19:52:16
I have a disassembled 45 engine, minus head and carb. Crank has been ground, Cam chd OK. Block has the usual cracks in upper webbing. The dist, oil pump, fan etc are all there, also gas tank. I got the tractor with the engine in pieces, but found a complete running one and put that in. Would like a reasonable offer. Where is as is. I'm outside Des Moines, Ia. Max
