Allis Chalmers D-17 parts needed
joe graber
06-29-2003 18:59:43
I am looking for parts on a D-17 S/N # D17-17642 of tractor. The gas motor S/N# 17-15119-M.
The govenor weight droped down and screw up the the timing gear and the governor gear.
timing gear, part# 70227038
water pump, part# 79003710
governor gear, part# 70229510
governor weight assembly, need qty. 2, part# 70229980
governor weight clip, need qty. 4, part# 70207719
governor pivit weight pin, need qty. 2, part# 70211368
Thanks If you can help
Joe
DanD.
06-29-2003 19:43:14
 Re: Allis Chalmers D-17 parts needed in reply to joe graber, 06-29-2003 18:59:43
You can get all of those parts right from your nearest AGCO-Allis dealer. Would be the easiest place and you'd get the right stuff. Would also be about the only source for some of the items you need.
